Show how belts route
SOURCE: belts slipping and breaking
If you are putting on the mtd belts and installing them right then you need to check bearings in variable speed pulley Also check idler and that no other pulley has been bent from installation.
SOURCE: Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
SOURCE: I need a drive belt diagram for a MTD mod# 13am77f7000 38''cut
Hi check out this site its called pats small engines just look up your model
SOURCE: i need a diagram to replace the deck belt on last
The process takes a little bit of navigation, but I'll try to lead you there painlessly.
The diagram search begins HERE.
In the center of that page, click on "LAUNCH ILLUSTRATED PARTS LOOKUP TOOL"
A new window opens and you will notice three (3) Tabs at the top-left of that page (Model, Parts and Product Line). Select the tab labeled "Model".
You will notice a Drop-down menu labled "Select Brand". Open it and choose "MTD" if needed.
Below that is "Model Search Criteria". Click the button to choose "Contains". In the box labeled "Model Name/Number" type in your model number.
**SPECIAL NOTE** Your TRUE model number is 13ao772g055 the fourth digit is the letter "o" and NOT the number zero, however, the ninth digit is the number zero.
Next, click the "Search" button and observe the findings on the right side of the page under "Details". Click open the folder labeled "Illustrated Parts Lists" and locate the page "Deck, 42 inch". Open that and you will have your Diagram and part numbers in printable format.
Hope this is helpful,
Dolf-
