SOURCE: D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
SOURCE: Connection of DVD writer having SATA cable
The blue ports on this motherboard are SATA ports.
This is a SATA cable:
SOURCE: Intel 815E Mother Board
Do you mean the Power Supply?
These are relatively cheap and easy to replace.
SOURCE: sata drivers for my mother board
Hello there.
Click here to download drivers for your Intel based motherboard.
You need to choose your version of Windows from the list to continue.
Hope this helps.
SOURCE: Intel 865GSA
Looking at the vendors I buy parts from, all the cards I saw offer both SATA and IDE ports. Here's one as an example. You definitely want SATA capability as most newer drives are only being offered as SATA, so you'll have a wider selection to choose from.
Another possibility: start fresh with a new system board. If the onboard IDE controller isn't working properly, this may be a warning sign that other problems follow. You might be better off spending your money on a new mobo that already supports IDE and SATA.
Hope this helps you make up your mind. Thanks for using Fixya!
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
