SOURCE: 2000 bmw 540 dashboard temperature gauge goes to
When a gauge goes bad, you have to decide if it is the sending unit or the gauge itself. If you unplug and short the wire to the sending unit, the gauge should go to max (one way or the other), and the opposite when the wire is not connected to anything. If that works, then it is probably the sending unit. If that does not work, it is probably the gauge itself.
Testimonial: "that works thanks"
SOURCE: poor starting problem bmw 318 ti
WARNING! Always wear protective eyewear, gloves and necessary clothing before inspection or work begins. Never crank an engine over when you are near the battery or engine. A battery is filled with explosive gasses that can ignite when extreme heat or a spark is present. A battery could have residual acid on the outside casing so use caution when handling a battery and the surrounding area. Use baking soda to neutralize any suspected acid residue before work begins.
You can check the car battery using a multimeter or voltmeter an electronic one is preferred , connect the black wire to the negative side (-) and the red to positive , WARNING :DO NOT CROSS THE RED AND BLACK WIRES OR SHORT CIRCUIT THE LEADS OF THE BATTERY OR MULTIMETER YOU CAN GET SERIOUSLY HURT!!!!! you should also get a spare watering can and fill it with water , (dont reuse for other purposes for safety) and remove those little tabs (usually around 4 or more) and fill it up very little in each tab/cap make sure you DONT fill it to the top. The good condition of a battery is 12.5 and 12.8 volts on the multmeter and when the car is started it
(not driven just started) should around 14V which shows that your alternater (acts as battery charger when driving) is working properly.
SOURCE: Hi I have 2000 BMW 320i. Lumpy idle when cold and oil light for
Your oil is a little low, and the timing may be off a bit but if it smooths out after warm it is probably ljust
low oil.
SOURCE: bmw 325tds diesel flowing back to tank when parked
usual problem ,valves in injector worn for the fuel pump.easy quick fix this one ,fit a non return valve in the inlet pipe,check flow direction on valve when fitting and evan better as well is another in the bleed off return pipe .valves available from a motor factor or a specialist garage like bosch or lucas ,cut pipe and fit the valve with a piece of rubber pipe to connect the valve in line.or listen to the people who want to milk the golden cow and have the whole injector pump overhauled .
SOURCE: bmw diesel wont start in cold weather, i have
YOU MIGHT HAVE TO INSTALL A BLOCK HEATER TO OVERCOME THIS PROBLEM
