My son poored moter oil in gas tank
Not a big deal. Im assuming this is a 4-stroke push mower and not a leaf blower.
Remove the air box cover, air filter, and air box back plate. Careful there is a gasket on the back of the backplate that if damaged the primer bulb wont work, part # 272653. Remove the fuel line from the carb and drain the tank. Using a 1/2 inch wrench remove the bowl nut from the float bowl on the carb, hold the bowl to the carb as to not break the gasket seal, drain the bowl and replace the bowl nut. If you tried to run the unit and oil is in the cylinder remove the spark plug ( clean the spark plug) and spray some carb cleaner in the hole and pull the starter rope several times to purge the cylinder. Reinstall the spark plug, reattatch the fuel line, install the air box back plate ( leave the air filter and cover off for now), add fresh fuel.
Take unit outside and start, you may need to give it a shot of carb cleaner in the throat of the carb to help it start. It may smoke, it may blow oil out the muffler. Let it run until it quits smoking ( usually around 5 minutes) . Shut it off and complete assembly. It should be fine.
Posted on Oct 08, 2012
Oct 05, 2012 | Toro Garden
Sep 16, 2012 | 1998 Nissan Quest
Jun 15, 2012 | Briggs & Stratton Briggs Stratton...
Jan 02, 2018 | 2004 Suzuki Grand Vitara
May 06, 2010 | Chevrolet 1500 Cars & Trucks
Apr 26, 2010 | Garden
Nov 03, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Sep 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jul 17, 2009 | Suzuki RM 125 Motorcycles
Apr 20, 2009 | Mtd 22" Yard Machine Push Mower
Jun 21, 2017 | Toro Lawn Mower With Toro Power Tools
82 people viewed this question
