Washing Machines Logo
kerry Posted on Oct 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water starts to pass through but then stops and error alarms start
ernesto cuadra
Level 3:
Top Expert:
  • LG Master 12,223 Answers
  • Posted on Oct 05, 2012
ernesto cuadra
LG Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080209
Points
34431
See this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
water starts to pass through but then stops and er - 10_5_2012_6_57_01_pm.jpg
Stop running and start blinking and setting off alarm
looks like water pump is stook with a coin or faulty
How to reset pass theft alarm on 2004 taurus
Try this,remove negative battery cable for 10 minutes,then reconnect,when you open door,alarm will go off,then insert key into ignition and alarm will stop.Should start up.
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
2answers
I started my car on day and the next day I unlocked the door and the alarm started and would not stop. My buddy diconnected the horn and the car won't start...help
i believe if you put key in ignition turn it forward and back off twice it should reset the anti theft to start it. or unlock pass door with key and that might reset it. also try the same with back pass door if the other didnt work. hope this helps.
7helpful
2answers
How do i reset the security system on my 2003 chevy impala
Are you reffering to the alarm or the pass lock system that put the theft light on.....If its the alarm the put the key in the door and unlock it. If its the pass lock system put the key in the ignition and turn it on and try to start the vehicle. After it shuts itself off leave the key on for ten min until the theft light stops flashing the turn key off and try to start it again. This may take a few times....
Alarm won't stop going off and car won't start
YOU MIGHT NEED TO BY PASS THE SYSTEM IF YOU DONT WANT TO MESS WITH IT OR TRY TO ALL THE SENSORS ON THE DOORS MAYTHEYRE NOT WORKING SOMETIMES THE RUBBER SEALS BRAKE AND THEN WATER MAY GET INTO THEM
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
