Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
The power is on to the washer. Door is closed. The lights will lit up when you select the cycle and the selected one flashing. pushing and holding the start button will not start the wash. Light is still flashing. No error massage. What could it be?
    Top Expert:
  • Kenmore Master
  • 12,223 Answers
See this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Kenmore Elite Model 110.42926 202 after setting th - 10_5_2012_7_06_37_pm.jpg
Posted on Oct 05, 2012
6ya staff
SOURCE:
Anonymous
  • 100 Answers
SOURCE: He3 Won't start - lock door or start water flow, although dispay works with no error
The door switch is damaged and needs to be replaced.
Posted on Oct 30, 2007
Anonymous
SOURCE: Kenmore Elite HE3 front loading washer
Before you go crazy trying to solve the F2 code make sure the filter is clear. Disconnect the power cord, PLEASE. Remove the kick plate on the bottom front by removing the 3 screws below it. You will need a hex socket and extension or a torx screw driver. If there is water in the machine and it will not drain you will need a shop vac and some old towels to catch the water when you open the filter. Now, you will see the filter in front of you. Have the towels ready and vac turned on. Quickly unscrew the filter cap and stick the vac hose right in the filter to catch the water. Clean the filter cap. Did you find any socks, money or other debree ? If yes that may have been your problem. Put the filter back on and HAND tighten well. Test the machine. From now on empty all pockets before you do the laundry. You just saved yourself a big repair charge. Be proud of yourself.
Posted on Apr 17, 2008
Anonymous
SOURCE: Kenmore Elite HE3 washer lights light but wash won't start
Sometimes I just have to unplug the machine, wait a few seconds and plug it back in and it works. I guess it resets itself or something.
Posted on Feb 26, 2009
Anonymous
SOURCE: I have a Kenmore HE3t
There is a black plastic piece that sticks out from the machine. It is located at about
2 o'clock. You probably broke off the piece as I did with mine. If you have a wooden skewer (or something like it), stick it in and depress the button. You can glue the skewer in place.
That should fix your problem.
Posted on Aug 17, 2009
Testimonial: "the post on August 17th fixed my machine. It was the button on the door that was broken off."
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Can't get washer door unlocked
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Kenmore elite washer will not start
The problem might be that the black pin (about 3/8" long and 1/8" in diameter), that normally sticks out of the frame of the washer at about the 2 o'clock position, and which is pushed in when the door closes, has broken off. If this pin breaks off, the washer will not recognize that the door has been closed. In my opinion, the pin is most likely to break when you close the door and the door was not properly aligned with the door frame -- in which case the pin will be sheared off. Let me know what you find.
Jun 29, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I had the main water shut off and forgot to turn it on before starting my machine. Now it is stuck. I unplugged it for a couple hours, then plugged it back in and the lights just blink and the cancel...
try this:
Press "Stop" two times.
Push "Power."
Select the button for the desired wash cycle.
Press the appropriate "Modifiers" and "Options" buttons to adjust the settings.
Push "Start."
thanks to here
Mar 06, 2011 | Kenmore Elite 45986 Front Load Washer
Error code F1 on Kenmore Elite "Oasis" clothes washer
Instructions Press "Stop" to clear the current cycle on the washer.
  1. 2
    Press the "Power" button to turn off the washer. Unplug the washer from the power supply.
  2. 3
    Wait several minutes. Plug the Oasis washer back into the power supply and press the "Power" button to turn on the washer.
  3. 4
    Select the desired wash cycle and press "Start."
Dec 12, 2010 | Washing Machines
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite front loader HE3 washer will not start.
The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
Eric
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite problem
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
534 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
