Bosch Axxis WFL 2060 Front Load Washer Logo
A
Anonymous Posted on Oct 02, 2012
Bosch Axxis Fault code F18 - Bosch Axxis WFL 2060 Front Load Washer
Syzys
Level 2:
Sergeant:
  • Expert 361 Answers
  • Posted on May 27, 2015
Syzys
Expert
Level 2:
Sergeant:
Answers
361
Questions
0
Helped
204196
Points
853
It's a classical error code, you can find all the error codes together with the troubleshooter within the manual under this article:
Bosch Axxis Washer Manual
4 Related Answers
uniman9310
Mike
  • 190 Answers
  • Posted on Jun 03, 2009
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Nov 29, 2010
SOURCE: my bosch logixx8 washing machine
Open the service flap, bottom right corner, and clean the pump.
That should do the trick
Anonymous
  • 6277 Answers
  • Posted on Feb 28, 2011
SOURCE: Bosch Exxcel 1400 Express -
Sorry but I do not know your particular machine even though we have a Bosch. I would suggest, however, as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Testimonial: "Many thanks - you were spot on but I got the info five mins earlier, Thanks again from Ireland."
Anonymous
  • 59 Answers
  • Posted on Jun 04, 2011
SOURCE: Error code F18 for Bosch Maxx 7 Silence washing
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly. http://www.espares.co.uk/parts?k=pump
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
2helpful
DESPERATE..... Displays fault code F18 frequently.Have cleaned the filter 3 times now recently(in the last 3 days) and is very clean but stopped again.Just emptied ll washing out of it and spun it to
I would check that the drain pipe is also clear.
You can actually get a build up of old soap powder in the pipework.
This pipe would be on the rear of the machine (grey in colour) and would connect to your waste pipe (perhaps under a sink)
If you can pull the machine forward and check to see if this pipe is indeed blocked, or even restricted.
I found this answer that may help you.
https://uk.answers.yahoo.com/question/index?qid=20120322120919AANhp8H
1helpful
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Bosch AXXIS WTL 86300 condensation dryer leaking water
5helpful
2answers
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
1helpful
F05 Fault code
this will be the motor brushes
Bosch Axxis WTL5410 condensation dryer does not heat up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
