Whirlpool Calypso GVW9959K Top Load Washer Logo
Posted on Oct 06, 2017
The LD light came one and the service called, but no good solutio
The LD light came one. We calle dth service man. He spent 20 minutes to check for the problems. Took another 10 minutes to open the front section. Took 5 minutes to open the back section. He than called his suopervisor. He adivised him to repalce the pump. The stimated cost of replacing the pump is over $500. We gave up and are lookng for a new washer.
  • Cindy333 Jan 07, 2009
    I am having the same problem, as of last night. When I called the repair man that we use, he actually said that the CALYPSO is the only washer he won't fix! Once they start having problems, they go downhill from there. I got the washer in 2002. I am not happy that I am starting the New Year buying a new washing machine!
5 Related Answers
Anonymous
  • 213 Answers
  • Posted on Nov 26, 2007
SOURCE: whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
A
Anonymous
  • Posted on Oct 17, 2008
SOURCE: Cabrio Washer LD error code
same problem here
wolfungarman
Sam Sebastian Farkas DaWolf
  • 174 Answers
  • Posted on Jun 02, 2009
SOURCE: F1 Error Code On Whirlpool Cabrio
Hiding within your washer should be a secret coded booklet that has all the error codes that don't appear in the user's manual.
F1 generally means the Central Electrical Control Unit (as in cars, etc) it is the onboard computer. It usually inicates a fatality.
If you do not have the skill & tools to test the guts of this computer, you're stuck replacing the CECU.
BUT if you have the skill & tools then there are three screws at the rear to expose the control panel, then unplug one unit; plug in the new one. Just to be on the safe side, color code all the plugs and replace.
The Unit is normally around $200 to replace, BUT aren't you still under warranty????
If so get Whirlpool to check it out and Replace it, lol.
cheers,
Bastian
Anonymous
  • 3 Answers
  • Posted on Aug 08, 2010
SOURCE: WHIRLPOOL DUET SHAKING & VIBRATING
I don't know what education or real world learning 'a1_appliance' has but his explanation isn't logical. I have nothing to do with appliances other than use them and fix my own when possible. I do have a degree in Mechanical Engineering and have worked in factories with machines much larger and faster than a washing machine. My comments below are based on education, experience, observation and applied physics.
  • What difference does the color of clothes matter?
  • What margin of error in weight of different articles of clothes is acceptable?
  • If one were to put in a load of all white Hanes t-shirts and then a load that weighed exactly the same but had a rainbow of colors with jeans, underwear, you name it, and you ran them on the same cycle, how would the machine know the difference? I would think the machine would operate the same for both loads.
  • Everyone likes to talk about balancing. One thing almost all moving machinery, especially ones operating at high velocities, linear or angular, to operate efficiently and not cause damage, is they should at least be leveled. The reality is that leveling and balancing are two completely different concepts.
  • You can level almost anything. Level (or plumb) means that with respect to earth/gravity, you have a surface that is exactly (within reason) horizontal (level) or vertical (plumb).
  • If you remember from high school or your last visit to the doctor, a balance means the weights or "forces" are equal. I don't remember my doctor bringing out his bubble level to make sure I was balanced. Balancing is the act of having a force (weight) that is equal and opposite the other force.
  • Consider these two very common examples.
  • 1. You can (and should) level a refrigerator, but if you have ever tried to lift one, wherever the compressor is located that side/end is always the heaviest. Refrigerators don't really have many moving parts so vibration isn't an issue.
  • 2. When I get my tires rotated, they balance them. They put lead weights on the rims to make sure they are the same weight. Some people don't want level cars. Balanced tires lessen the chances for uneven wear on the tires, alignment problems and other mechanical damage issues.
  • Apply the previous examples to a front loading washer. It can be spot on level and on a solid base but that just means it won't look like it is leaning or tilted. Since balance is not related to level, why would anyone make us believe the machine is balanced because it has been leveled. Because the only solutions to balance these machines would be expensive and would require some of the biggest appliance companies to admit a major flaw in design. Look on most of these companies websites and see how many are now offering Top Loading HE washers.
  • Why are the front loaders subject to so much vibration? Here is a way of "feeling" what I mean about balance (not level) as a the cause for the severe vibration. On your front loader, lift all four sides; one side will be heavier than the other (the back). The machine is not balanced. In comparison, older top load machines used to vibrate but in general that was because they were not leveled properly or the spinning tub had too much "play", but this was a sign of wear and tear and could be (usually) easy to fix. These machines lasted years and the real vibration issues gradually increased over ten as opposed to the first loads. If you lifted the four sides of these, one side may have been heavier but only by a little. They were bottom heavy and the clothes (weight) were supported by the motor drive and the ground. The force of the laundry was balanced by an equal force (earth) Front loaders are back heavy and the loads spin in front of the drive. This means (as noted in one of the answers above) talks about the load eventually accumulating at the bottom and staying there as the machine spins faster and faster. The weight of the load is now pulling the drum with increasing force in a continuous circle around the face of the washer. With no "equal and opposite force" to counter it, the machine has no way of being in "balance."
  • I know some of you are saying the centripetal force in a top loader would cause vibration issues. It would if the drum was not given some ability to move laterally to compensate for this. And unlike front loaders, top load machines, when loaded normally, after the wash cycle, the clothes settle to bottom relatively evenly. This means that in a perfect situation with the weight of the load evenly distributed around the sides during the spin cycle, you would have equal, opposite forces around the entire drum.
  • To make things worse, the front loaders were not tall enough so that encourage people to buy "pedestals" with a plastic drawer to raise it to a reasonable height. Now an unbalanced machine rests on a four sided stand with no significant weight. We designed a bad machine so lets make it worse by accentuating the problem.
  • As for a solution for myself, I'm not going to fight a losing battle and fight with Whirlpool. I am going to try something that I am hoping will alleviate the problem of the vibration (and noise). Just as ships have ballast in the hulls to keep them from toppling over, I am going to try filling my pedestal with something very heavy. Lead would be great but I have kids so I may try pieces of rebar or some other dense material that will counter the forces pulling the machine upwards.
I hope this makes sense and helps people see that balancing does not mean leveling. I hope my examples were clear enough that everyone can see why this issue is inherent to all brand of front loader.
Jamie
Anonymous
  • 15935 Answers
  • Posted on Sep 20, 2010
SOURCE: Whirlpool CABRIO WTW6400SW2 Washer shows F1 code
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
also are the coils clean?
My fridge is not working
4. Wait one hour.
Try this and let me know.
have a good day
2answers
Printer Trouble error message on NEC DTH-16D-1(BK)
SAME PROBLEM:
Hello jlaverty,
Did you ever figure out how to fix this?
We just had a long power outage last night and our phone system wasn't accepting outside calls this morning. We reset it, which fixed the problem after 10 minutes or so of waiting.
The new mystery is why the admin phone is now flashing this "Printer Trouble" error message.
Thanks,
Brian
3helpful
THE CODE LD IS SHOWING UP AND WASHER IS NOT OPERATING
Press stop, cancel twice to reset. The Ld error is when it takes longer than 5 minutes for the washer to drain and reset the sensor. You probably have a partially plugged strainer or drain line. To check the strainer, remove the kick panel at the front bottom of the machine. The strainer is ibetween the drum and the pump, being connected to the drum with a rubber hose. Open the strainer (caution, water!), and clean. If you did not find much in the strainer, clean the drain hose. Dump the contents of the drain hose into a bucket. If possible, run an empty losd with dth drain line pointed outside.
This should fix your issue!
Best regards, --W/D-- feel free to rate this solution...thanx!
2helpful
I know today it was 99* but my moms a/c isn't cooling?I took the filter out and man o man the fins or coils are covered with dust?can i clean them or do i need a Pro?I'm not sure i can get my hand all the...
call a reputable co. get it tuned up most have maintenance programs, should be checked yearly.you will be time and money ahead the out side unit needs to be cleaned to. and what you spend on cleaning the unit you would have spent trying to cool a house with a dirty unit that has very low performance. good luck Tom.
Recall last phone call to see number
Press "Redial" then *(star). The redial key is a multifunction key. You can either use redial or utilize the phone system speed dial directory.
1helpful
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
2answers
I have a cabrio washer and keep getting LD error code, washer looks to drain fine but won't advance on to spin cycle - sits there for a few minutes trying to drain even though no more water is in tube,...
Friend,
ngfam1 At your service!
When it is a code the machine is telling you that there is a fault and the electronic system needs to be diagnosed by a trained tech.
My advise is,
You spent enough money buying that Cabrio to be experimenting and guessing and buying expensive parts for it!
Let the tech fix it 123 and your done. It may not have needed the drain pump and now that money could have covered the service call!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
2answers
Washer Problem
cabiros dont have a wig wag switch check your drain pump for obstructions to find the right repairman go to www.whirlpool.com under support enter your zip code under find a service tech and they will give you a list of people in your area
3answers
LIGHT ENGINE REPLACED
first of all, was this an authorized Mits. servicenter? if it was, call Mits. customer svc & complain. they should get someone authorized out there to give u a definite answer at NO CHARGE. wanna buy an extended warranty? let us know, thanks, alan audio video designs 3822 s. staples, cc,tx 78411 [email protected] 361 8577236
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
