The bottom of the freezer door is the only place where frost/ice is collecting. The temperature in both the fresh food and freezer compartments remain steady as set. Thanks for your help. JG
SOURCE: Frost buildup
It is not defrosting. You have to remove back wall of freezer where frost is and take hairdryer to melt away frost. You need to check defrost heater. This is on bottom of evaporator coils. It has wires going to it on both sides. This has to be checked for continuity. If ok on top of coils is a round unit called a defrost terminator. This needs to be checked for continuity also. This must be done before you defrost coils. It should have continuity when its cold.
If these are ok you probably have a bad timer or defrost board.
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
SOURCE: hotpoint side by side csx22grbk serial vz247504
chances are you have a faulty module (board) sounds like you'll have to call an engineer oput to replace it
SOURCE: My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
