Generac Generator 5987 2,500 PSI 2.3 GPM Gas Pressure Washer Logo
Steve Lamb Posted on Oct 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Generac pressure washer will not run unless trigger is pulled
To start pressure washer you must hold the trigger in. when you release trigger, engine dies
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on Oct 15, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2131221
Points
13357
The pressure regulator is stuck inside the pump
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
5439
Points
8
Wonderful.
Share a website with you ,
( http://www.wholesalemkt.net/ )
Believe you will love it.
We accept any form of payment.
1helpful
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Generac 6hp pressure washer starts and runs fine, no real leaks, but it never builds up pressure.
after making the water connections, be sure to hold the trigger open on the wand for a couple of minutes before starting. All the air must be removed from the system before it can create pressure.
My Generac pressure washer will work great for as long as I hold the trigger. If I release the trigger to move something or change positions and then pull the trigger again the pressure doesn't come...
Sounds like the unloader valve built-in to your system is sticky. Try lowering the pressure of the regulator to lowest setting then re-adjusting. This will place a different pressure /load on the valve. Also when you store your unit, displace the water in the pump with oil so that lubricant will prevent the unloader from sticking. If you continue to have problem, replace the unloader. Good luck
Too much pressure.
You need to keep the trigger pulled every time you start and you need to run the water for 3-5 minutes wide open before you start. Zero air should be in the line or this could cause it to **** out. You probably damaged the pump at this point.
4helpful
New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
2helpful
Pressure washer hesitates, does not start. Unable
get someone to keep the trigger pulled while you try to start it , its probably got presure trapped between the trigger and the pump.
alternatively turn off the water to the pump, pull the trigger to release any pressure trapped.
start the engine , allow engine to warm up, increase revs on engine then turn on water, should be ok then. Unless you have a problem with the engine that is!
13helpful
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
On a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
