Whirlpool Duet GHW9150P Front Load Washer Logo
A
Anonymous Posted on Oct 02, 2012
Whirlpool duet tumble fresh 4.4 F28 code? - Whirlpool Duet GHW9150P Front Load Washer
Jason Johnson
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 15, 2018
Jason Johnson
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1192
Points
F28 code with no red light showing for the locked door. The washer would lock the door and then become stuck in the locked position. I had to reach up and pull the latch release manually to get it to open, but then the same thing would happen. I eventually could feel another wire was up inside there and not connected to anything. I had to remove the top of the washer along with the door and door trim ring. Then removed the front control panel (the front panel swings out from the left side and is more or less kind of hinged on the right. Dont swing it too far just enough to pull it straight out after the left side is 4 to 6 inches out. Leave it plugged in and set it on top of the washer) I then removed the screws to the steel front panel that is around the door. Remove the latch and pull it out the right side just enough to get at the broken wire and the clip it came out of. I soldered the wire back onto the clip and reassembled the washer. It is working great now. Hope that helps someone else. I was almost ready to buy some expensive parts that would not have fixed the problem in my case.
5 Related Answers
Anonymous
  • 220 Answers
  • Posted on Sep 13, 2009
SOURCE: What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Anonymous
  • 63 Answers
  • Posted on Oct 28, 2009
SOURCE: whirlpool duet f28 code
Turn off the power. Remove the detergent tray. Reach in the slot where the detergent tray fits and look for a lever. Pull it and replace the detergent tray. Turn power on. Good luck.
Anonymous
  • Posted on Dec 13, 2009
SOURCE: whirlpool duet washer
Must be a problem with this washer, because mine is only a year old also and keeps showing F 28. You start the wash and the door locks, then unlocks, then locks again and doesn't continue with the wash and then blinks on the screen F 28. This is so frustrating when money is low and your new washer is already screwed up. I'm going to get a hold of Whirlpool is and see what they can do.
Anonymous
  • 15935 Answers
  • Posted on Sep 21, 2010
SOURCE: whirlpool duet washer, error code f28
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Anonymous
  • 15935 Answers
  • Posted on Sep 28, 2010
SOURCE: WHIRLPOOL DUET SPORT WASHER FLASH FAULT CODE F28
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
1helpful
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Whirlpool duet steam front loading
go to this link ........... it will show you step by step solution
http://www.ehow.com/how_8052747_fix-f28-code-whirlpool-duet.html
1helpful
F28 code on whirlpool duet washer. The door locks
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
3helpful
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
You can download the online repair manual in the below link
On page# 4-20 it shows how to access your MCU.
4helpful
2answers
F28 CODE
Here's the online repair manual for your
Whirlpool Duet
Give it time to download.
10helpful
7helpful
F28 code washer stops working. Reset will only
Error code F28 indicates that one of the below part is bad
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) you can fix it,
Here's the online repair manual for Whirlpool Duet Sport, but its identical to your HE2.
Refer page# 4-20 it describes how to get to MCU.
6helpful
Whirlpool duet f28 code
2helpful
3helpful
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
