I would like to replace the carburetor on Husqvarna 240e chainsaw. How do you open the casing to remove the carburetor?
Remove the handles, then remove four 8MM bolts from the bottom securing the engine case. The entire assembly will then rotate upward,
allowing you to remove the two 8MM nuts and carburetor.
Its under the top cover but before changing the carb what problem are you having?see more plugged muffler screens then bad carbs
SOURCE: My husqvarna 359 chainsaw blows fuel out the exhaust
You need a carburetor kit. The needle valve in the car. is stuck open. The needle valve helps to control the flow of fuel.
Jim
SOURCE: I have a Husqvarna 55 chainsaw that has a crack in crank case
YOU MAY BE ABLE TO GET THT ONE WELDED WITH A TIG
