Are you using vga out on notebook ?
are you using vga in on projector ?
Turn on projector
hold down function key on notebook when turned on - FN button and press F5 - cycle through each mode by releasing f5 and pressing F5 again till you get CRT or CRT + LCD (while keeping FN pressed )
on data projector input source should be computer or vga
SOURCE: LCD screen is blank when lap top is on
I would suggest ensuring it's not video chipset. You have a VGA (monitor) conenctor on the back of that, plug in a regular computer moniter and see if it works. If it boots on the monitor you know it's a display problem(hinge,ribbon cable), if it still doesn't boot, it's a hardware problem(video card, main board). Let me know what happens, try cleaning the hing with rubbing alchol & a q-tip Good luck Hope this Helps!
SOURCE: Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
SOURCE: Problems with Toshiba DVD Player
According to this Toshiba document a new soud driver installation will help you to solve this HD-DVD issue.
Check this;
HD DVD title doesn't play ("Unable to output the video to an external device")
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1664788xml&sliceId=&dialogID=24590306&stateId=1%200%2024588233
