Sunroof motor is broke, got new one and need to know how to wire the new one
SOURCE: 1998 toyota ipsum car stereo wiring
Clck here for the correct wire colors for Toyota. http://www.autotoys.com/New_Tech/Wire_codes/TOYOTA_WIRE_COLORS/toyota_wire_colors.htm
SOURCE: need Toyota Camry radio/cassette/cd model 86120 33100 harness
You can try any Circuit City or any car stereo place or you can wire it yourself you just have to figure out which wire is power,ground,front and rear speakers. Yeah the hornance makes it easier but it can be done without it
SOURCE: I need a spark plug wire diagram for a 1992 Toyota
1992 Toyota Camry Sedan
3.0 liter DOHC V-6 (3VZ-FE)
Cylinder # Front, passenger to drivers side 2-4-6
Cylinder # Back, passenger to drivers side 1-3-5
Distributor 12 O'clock post # 6 cylinder
10 O'clock post #1 cylinder
8 O'clock post #2 cylinder
6 O'clock post #3 cylinder
4 O'clock post #4 cylinder
2 O'clock post #5 cylinder
Good luck and hope this helps.
SOURCE: need wiring diagram for 99 Toyota Camry stereo
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
SOURCE: need wiring diagram for computer wiring for 1994
There's a service manual for '93 here ... (since 94 was the last year of that series I doubt if much changed):
http://myweb.dal.ca/is353832/93fsm/
