It isn't working, and i just want to know what is wrong with it, because i don't know if the problem is that the right front speaker plug is broken. Does the right front speaker need to work in order for the whole speaker system to work?
The whole system can still work with or without it.
Here is an additional tip how to .....
Computer Speakers
SOURCE: Altec Lansing speaker - model ada 745
I am guessing you mean the cord that goes into the PC, I don't know how "Broke"it is, but you should be able to cut the old end off and replace it, if you buy an inexpensive speaker extension cable, you can use that for the new end, or try radioshack, they may have replacements that just need to be wired, usually a black and red wire is all, just tape it up good to avoid shorts
