Question about KitchenAid KESC307 Electric Kitchen Range
F2e0 error on stove
What does it mean to cycle the circuit breakers in order to fix the f2e0 error on the stove? thanks
  • Anonymous Jan 17, 2009
    I have a kitchenaid stainless steel gas range and it is displaying the F2EO message. I don't have any paperwork on this range. Can anyone help me.
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Posted on Apr 17, 2009
  • 198 Answers
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
F4
F6
F7
F8
F9
Posted on Jan 05, 2009
6ya staff
SOURCE:
I have GE Oven/Stove combo Model #326B1230P001. I get an error message F7 & Flashing E7 code and it beeps. How to fix this?
this error for GE means that your touch control panel has shorted and the entire touch control panel would need to be ordered and replaced if resetting the circuit breaker won't reset the issue.
Oct 13, 2018 | GE Ovens
How do I fix my stove? None of the radiant elements are working.
Have you confirmed that you do have 220 volts at the range outlet? If you don't, turn your breaker off then on and recheck the voltage with a meter. Any losses of voltage through the breaker indicates you may have a bad breaker. (Do this with the stove unplugged from the stove power receptacle). Next, have you pulled one of the elements off the stove and checked it with an ohm meter to see if you have continuity. No continuity indicates the element circuit is incomplete and the element needs to be replaced (you should have a reading on the ohm meter if the element is good).
Dec 30, 2014 | Samsung Electric Convection Range...
PF code
Depending on manufacturer and model, PF can mean a number of things. On my stove, PF simply indicates "Power Fail" Yours may, too. You can clear this generally by updating the clock display. To verify that PF does indeed mean power fail for your stove, simply shut off the power for the cicuit than supplies the stove. This can be either circuit breaker or fuses. Turn the power back on after 5 or more seconds and if it displays PF again, you know it means power fail.
Otherwise, please provide the manufacturer and model of you stove for an answer.
Jul 02, 2012 | Ovens
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
How to fix F2E0 error on Kitchenaid stove ?
Your electronic range control clock has gone out on this unit. You can contact us at accurate-appliance-service.com for all your parts. We can get the correct part out to you right away.
We hope this answers your question and the best of luck to you.
Oct 26, 2009 | KitchenAid KESC307 Electric Kitchen Range
GE Spectra flat top stove electrical short
Go to your electric circuit panel. Locate the breaker for the stove. Turn it all the way OFF then back ON. This should correct your problem.
Aug 18, 2009 | GE Kitchen Ranges
Kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
F2e0 error on stove
"cycle the circuit breakers" is to turn the switch for the stove at the electric switch box at the main feed of the house electric panel. This is equivalent to unplugging the stove and plugging it back in.
In the old days, a circuit breaker was a "fuse" in the "fuse box"...
Kitchen Aid KESA907 Error F2E0 Stuck Key
Turn off the breaker and wait for 5 minutes. the follow these steps:
Apr 24, 2008 | Whirlpool GERC4110PS Kitchen Range
Kitchenaid glass top electric range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
May 27, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
5,946 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
