Kenmore 22422 Top Load Washer Logo
Mike Iannone Posted on Apr 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Series 70 Kenmore Washer Won't Agitate or Spin
My Kenmore 70 series washer will not agitate or spin. It makes a loud clicking noise instead of begin the agitate or spin cycle. I even tried it empty to see if it was an overload.
  • 8 more comments
  • Mike Iannone Apr 27, 2007
    Sadly, the gears in the transmission are broken. My wife wanted a new machine anyway. Thanks for the help!
  • Anonymous Oct 10, 2008
    My wife reports to me that our Kenmore 70 series washer does not agitate or spin. She thought the clothes made it through a complete washing cycle, but the clothes seemed too wet, so she put the clothes back on rinse and spin cycles, but the agitator and the drum (basket) would not move.
    When I got home I vacuumed the water out of the mashine and tried it in every setting. The agitator barely moved, but I could hear the hum of the motor.
  • Anonymous Mar 16, 2014
    Makes a loud noise while agitating, it doesn't want to spin
  • Anonymous Mar 17, 2014
    kenmore 70 washer not spinning just making noise
  • Anonymous Mar 19, 2014
    makes noise when spin cycle
    make noise when Drain/Spin Cycle
  • Anonymous Mar 24, 2014
    Washer isn't spinning and making a weird noise instead
    it makes a humming noise and doesn't move.
  • Anonymous Mar 27, 2014
    spins but will not agitate
  • Anonymous Mar 30, 2014
    washer will not spin
Anonymous
Level 3:
President:
  • Master 878 Answers
  • Posted on Apr 27, 2007
Anonymous
Master
Level 3:
President:
Answers
878
Questions
Helped
1202202
Points
3312
Baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
1helpful
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
1helpful
2answers
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
2helpful
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
11helpful
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
62helpful
8answers
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Alexander
vince
