The door alarm keeps beeping so I cant start a washing cycle
Do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
SOURCE: faulty door which keeps beeping
I had a similar problem which was resolved by replacing the door interlock switch (cost about £10.00).
To get to it you need to disconnect the mains then remove the top lid. You can then see it by looking down the inside to the right. Remove the 2 screws inside the door opening and you can then lift it out after disconnecting the wiring plug.
Replacement is the reverse of the above, a 5 minute job.
SOURCE: Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
SOURCE: The door locked light keeps flashing on my
Sounds like needs new door interlock swith Cost around 15 pounds.....Simple to fit
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
[email protected]
pallesappliancerepairs.com
