I need to recover deleted web search history from my iphone 3g
Deleting important call history wrongly may happen to many iPhone users. If you are one of them, you must be very anxious now and look for methods for how to recover deleted call history on iPhone. No need worry at all. Because I can totally help you with it.
Many of our readers, loyal and satisfied customers, have encountered this problem, and wonder how they can recover their call history from their iPhone. There are three ways which you can use to recover the iPhone's call history.
All you need to do is to get a professional iPhone recovery software which can help us get the call logs back, and Fonedog- Recover (iOS) is such a tool.
Solution1: Recover deleted call history directly from iPhone Using Fonedog Recovery.
Solution 2: Restore deleted call history via iTunes.
Solution3: Retrieve deleted call history via iCloud.
More Info: How to Recover Deleted Call History from iCloud Backup File
For us to be able to securely recover deleted call history from iTunes with no data loss, you need to use third-party recovery tools. FoneDog iOS Data Recovery is the popular choice among all iOS users globally because of its user-friendly process and effective methods. It has three recovery methods you can choose from: 'Recover from iOS Device, Recover from iTunes, and Recover from iCloud'. All these three options are very easy to use that this software was tagged as the most customer-centric recovery tool.The lost data can be in any form-contacts, video, voice notes. To learn how to recover deleted call history from iTunes without having to lose your current data, follow these steps:
Step1. Launch FoneDog Toolkit-iOS Data Recovery and Choose 'Recover from iTunes'
Step2. Scan, Preview, and Recover Call History
Retrieve Removed Call Chats from iPhone Without Backup
1. Run FoneDog Toolkit-iOS Data Recovery and Connect iPhone to PC
2. Scan the iPhone Device
3. Preview and Recover Call Chats
Now that you have learned how to recover deleted call history from iTunes, you can now value the importance of having backups especially the iTunes. Yes, backups may seem unnecessary at times but we always remind our users to keep them a habit. You will never know when you need backups unless you are in great trouble. Download the Free Trial version of FoneDog Toolkit -iOS Data Recovery and discover which method works for you!
Completed guide: How can we recover deleted call history from iTunes and iPhone?
Part1. Common Causes of Call History Loss
There are other reasons too that can trigger data loss and below are few of the most common:
Part2. Recover Deleted Call logs on Samsung Galaxy using FoneDog Android Data Recovery
There are greater chances to recover deleted call logs using programs like FoneDog Android Data Recovery compared to other methods because of the following features:
There are thousands of recovery programs available in the market but FoneDog Android Data Recovery knows how to better handle your issues professionally and with all the key features above, who can go wrong with this software? For you to be able to recover deleted call logs, follow these guides:
step1. Download FoneDog Android Data Recovery, Install and Launch on The Computer
Step2. Connect Samsung Galaxy S5 to The Computer
Step3. Select Files to be Recovered
Step4. Start Scanning the Handset
Step5. Preview and Recover Deleted Call Logs
More refer:
How to Retrieve Deleted Call Logs on Android phone?
Quick Guide: How to Recover Deleted Call Logs on Samsung
For deleted data and file on iPhone, they will still be there till new data overwrites them. So as long as we find them before its being overwrote, we can recover deleted history from iPhone.
Surely this mission cannot be completed with just an iPhone, we also need help from other tools:
How to Retrieve Deleted History on iPhone with PhoneRescue
Step 1. Launch PhoneRescue on your computer and plug your iPhone into computer with a USB cable. Choose "Recover from an iOS Device" mode. And click Next to scan deleted data.
Step 2. After scan, select Safari history to preview deleted history by using the filter on the top-right corner, and then click Recover buttons on the bottom to get back them to your iPhone or extract them to printable document.
What a nice question for me to answer it with this easy iPhone recovery tool Whatsapp Recovery for iPhone all your file can be retrieve that you have mistakenly erase. Just try this it will help you a lot. :) See more details here in Whatsapp Recovery tutorials.
In order to recover deleted iPhone Call History for iPhone, the easiest way is using iTunes, it't free.
Click the File menu and select Devices > Restore from Back up.
Or
Open the iOS device's Summary tab. There are two ways to access this:
Click the device button in the upper right corner. (If viewing the iTunes Store, click the Library button in the upper right corner. The device button will then be visible.)
From any view in iTunes, click the View menu and select Show Sidebar. Select your iOS device in iTunes under Devices.
Click the Restore Backup button.
Read more
free any iPhone data recovery
Following steps can help you to recover deleted history on iPhone 3G
1.Connect your iPhone and Scan it-- After downloading the iOS Data Recovery, run it on the computer and connect your iPhone with the computer by a USB cable. Then click on the "Start Scan" button. The program will begin scanning your iPhone for deleted messages on it. Don't disconnect your iPhone during the whole time.
2.Preview and Recover Text Messages from your iPhone-- When the scan finishes, you can see all your found data listed in clear, organized categories. Choose Messages and Messages Attachments to preview the detailed content. And click what you want and click on Recover to save them on your PC.
Thanks
If you want to recover call history on iPhone, you must to use a iPhone Call History Recovery, the use guide about how to recover call history on iPhone is not bad.
Next,let's shows you the way to recover iPhone/iPad call history:
One. Recover Lost or Deleted call history from iPhone directly
1. Connect the iPhone to computer
2. Scan your iPhone device with iPhone recovery
3. Preview and restore iPhone call history
If you have iTunes backups, just recover the deleted call history on iPhone from the previous backups.
1. Connect the iPhone to the computer with a USB cable.
2. Open iTunes.
3. If you have a new or erased iPhone, iTunes will prompt you to restore from backup.
4. Otherwise, Control-click on your iPhone under devices in the left menu.
5. Select Restore From Backup...
6. Choose the backup you wish to sync and click the Restore button.
Tips:You better backup iPhone data to computer, avoid losing call history and recover deleted call history from iPhone.
Actually, there are two ways to recover lost contacts of iPhone, one is from the iTunes backup files, another one is recover them directly from the iPhone with the help of iPhone Data Recovery software, since you are wondering about the way without the using of iTunes backup, you can choose a kind of iPhone Contact Recovery software to recover your contacts in a few steps and it is very easy and fast, you can have a try!
How to Recover Lost or Deleted iPhone Contacts
Professional iOS Data Recovery Software for Personal Users
Hi the history should be in your back up on your pc if you synchronise your iPhone with iTunes. Just connect your phone to pc open iTunes and press right mouse button on your iPhone in the list on the left hand side and choose restore, then choose the appropriate date and iPhone gonna restor to that date but you can loose all new data
HOW DO I DELETE THE BOOKMARKS AND HISTORY SECTION OF MY IPHONE 5?
