KitchenAid KHWS01PMT Front Load Washer Logo
A
Anonymous Posted on Sep 27, 2012
Water coming out of the bottom of the machine
There appears to be water on the floor in front of the machine after a wash, not a lot but def some water
Anonymous
Level 2:
Novelist:
Filmmaker:
Uploaded 5 video answers.
  • Expert 54 Answers
  • Posted on Sep 28, 2012
Anonymous
Expert
Level 2:
Novelist:
Filmmaker:
Answers
54
Questions
0
Helped
16265
Points
128
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
1 Related Answer
Anonymous
  • 1036 Answers
  • Posted on Feb 07, 2010
SOURCE: my front load washing machine won't spin and drain the water
Check that it is actually heating the water in there. If the heating element has gone, then it will fill, then wait while it heats up the water needed - which it can't, so will just sit there full of water.
Usually involves taking the front off, which isn't easy.
Try it on a rinse and spin and see if it does anything, then you will know better what part is actually causing problems.
Hi I have a Hoover HNF7167. Machine was on a normal wash. When the cycle was finished the clothes were extremely wet. Put on a spin, still very wet, tried the drain cycle but this didn't work. I took...
Same problem here except the filter was clean. Got a new washing machine coming tomorrow. Looks like it could be the pump BUT after reading various web sites and auction sites it looks like it may also be the circuit board.
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
2helpful
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
Water leaking from Washer during cycle
you can remve a few screws(3) across the bottom of the unit.( just above your "add-on" drawer. 3 torx 20 screws and after removing the acess panel youll get abetter look as to where exactly you water is coming from
Water leaks onto the floor during every load. The water appears to be comeing from the front right hand side.
Please check the water tap connected to the washing machine. Sometimes it may be leaking.
2helpful
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Water coming out of dispenser drawer!!
You said you took off the hose from the back, okay this hose was clamped somewhere below - this is where the block is. Your outlet filter. It requires periodic cleaning - is a place where you can remove (see manual 'cleaning filter')to clear out whatever. For many front loading machines the place to open is at the front panel, right or left bottom, a 4.5 by 4.5 door. Clean out, refit.
Top KitchenAid Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
