No cranking when key is turned
If you havemade sure the battery and conections are good check for a fuse for the start circut or lights most tractors have a switch under the seat that killsv the engine start circut check thisvand make sure that it is not your problem yuose a volt meterv or test light to check power to all the battery connectios
what have you done so far? Cleaned the battery connections? What's the voltage of the battery?
