REPAIRING MAKITA HR3000C AND I CANT GET THE DRILL/HAMMER MODE CHANGE SWITCH OFF
SOURCE: Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
SOURCE: whats it mean whene the top light comes on and it
green light up : all electrical contacts are ok
red light on : time to replace carbon brushes ant if possible bring back for maintenance kit
SOURCE: I've got a Makita HR3000c and it won't hammer.
more than likely the o rings are worn such that it won't seal. You can go to Makitatools.com and download a breakdown for this tool and see all the parts needed to rebuild. Let me know if you need more assistance.
SOURCE: how do you remove the
Removing the change lever:
Set change lever at neutral position (arrow pointing down) and insert a slotted screwdriver into the back of the lock button. Slightly hit the screwdriver with a plastic hammer to remove it. Good luck with your repair.
