The Kenmore model is 106.76246400 The water to fill the icemaker will not stop flowing, causing the icemaker to overflow into the ice bin and throughout the freezer. Raised the bar on the icemaker to turn it off and turned off water supply to temporarily halt the water flow. Now what?
SOURCE: Water doesnt stop after ice tray is filled
My amana sxd25s2w side by side, water dispener just stopped working all at once. I hear a click when pushing the bar, and the light goes on but no water. Also the ice maker is over flowing when it fills the tray. Are these 2 things related and I would like to replace the filter for the water , where can I find that. Please help!
SOURCE: too much wate flow into icemaker
it over filling or it leaking from the mold i never seen thi model over filled mold when i see wtr in bin is usually the mold that is leaking you can check with a mirror or remove to inspect is texture is peeling off repl entire ice maker if is ok then repl wtr valve is not closing when it has filled the mold you only need 4oz of wtr
SOURCE: Too much water getting to ice maker
The little cup that sits in front of the hose that dispenses the water, has frozen water in it . Check that first and if it's OK, then there is a small screw that you can adjust, look at your manual.
