SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
SOURCE: How do I replace the main drive belt on a
No you don't, it's easy. Pull all the cotter pins out of the deck mounting brackets until the deck is laying on the ground and slide the deck out to the side. Make sure the parking brake is engaged so you have enough slack for the belt and start in back and work your way forward. You should see a little picture there somewhere on the mower of how to thread the belts through the tension pulleys. Then, put the deck back on.
SOURCE: i am looking for owns manual for craftsman lt1000
you can find owner manuals at sears parts direct .com
SOURCE: I'm having trouble replaceing the motion drive
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
