So i just started the game and i walk outside the apartment and the screen goes in circular motion. Then it stops for about 10 seconds and starts again.
SOURCE: Wobbly Laptop Screen
Raven,
This is not for the faint hearted and because there are many types of different hinges used i cant be absolutley specific but here goes any way :)
You will probably need to lift the caseing aroung the top of the keyboard, then the caseing around the screen. There generaly lots and lots of small screws involved and some locking tabs.
I find the best way to deal with the locking tabs is to tease them open with something like a jewellers screw driver and then use
You should then be able to get to the hinges for the screen. The main problem I've seen with loose hinges is the plastic fixes for hinges have broken and the screws have fallen. If this is the case there isnt a great deal you can do other than replacing the screen caseings.
Hope this helps, if you need any more assistance please dont hesitate to ask.
Regards
Nick
SOURCE: 1 Long Beep & Blank Screen Then Starts Up. (Acer 5715z)
No, if everything is starting normally
SOURCE: When I start GTA 4, My game camera spin....
Have you tried to check for game patches/updates to see if this is a common issue and have been solved?
Here´s a patch: http://www.fileplanet.com/195520/190000/fileinfo/Grand-Theft-Auto-4---Patch-
Also, try unplugging any joysticks you may have connected.
SOURCE: inspiron e 1505 does not turn' on
It could be a couple of things, but it seems most likely that it is the RAM Memory that is causing this. You might need to add more. I have seen this before with one of my customers, we upgraded his ram from 1.5 to 2 gbs, and his games/windows no longer crashed
SOURCE: Hi, the backlight on my IBM T60 screen goes out
Could be the lcd inverter goin bad ,,thats what powers the lcd backlight,,so in this case check ebay or internert,,but either way cheaper and easier to fix bein the inverter,,right un lcd bezel ,,its in the middle on the bottom ,,one screw,,swap for new one and you should be in buissiness,,goodluck
