Top left infinite burner switch went bad. Need a new one, but there are two to pick from on the parts list 700855K or 715230K. Which one do I buy? The old switch has the following on it: INF240P-703 15400-B 15AMP, 240VAC
Go to www.repairclinic.com and buy it
God bless you
SOURCE: Spot on Jenn Air smooth cook top stove with down draft.
I have a strong draft coming up through my Jenn AIr cooktop. What to do?
SOURCE: how do i replace my burner on my jenn air ceramic
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
SOURCE: Jenn-Air electric stove top - burners/fan won't come on
I had the same problem. Went to an appliance store that carries Jenn Air. Replaced both plug in units. Now they work perfectly and it cost less than $350 total! Good Luck!
SOURCE: I have an old Jenn-Air cook top with down draft,
Hello. Work directly with Jenn Air on this. Go to this link which includes a toll free number and a link to IM with their technician, for free.
http://www.jennair.com/flash.cmd?/#/page/customerservice/
SOURCE: Replacing an old jenn air
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
[email protected]
406.471.0000
