I am trying to find a front display panel for a sony ta-ve110 av amp it is quite an old unit now but my daughter loves it it was dropped on its front and the board snapped.Any help would be most grateful,i would like to fix it because it is only slender and fits the space in her room.
Go to www.sony.com contact customer support and the technical department to see if they can help, also try www.ebay.com type make and model and go through the list if available.
SOURCE: Sony TA-N9000ES Flash light when turn on.
an amp of this size generates alot of heat internally when in use as these use mosfet ICs and can get very hot.
your problem is most definately dry solder joints and possibly quite a few at that.
i've repaired quite a few sony surround receivers with similar problems and have all been down to dry solder joints.
hope this helps.
SOURCE: i own a ta-9000pre/pro and
Hi First of all please check that all the cables firmly
connected to/from the unit. If every thing is fine then you can upgrade the
firmware by following step by step instructions on the link. You can
also download the service manual for TA-E9000ES from this link. However all the
components of this unit are under 5 year's warranty. If this period has already
been elapsed then you can also buy the replacement part 71V124SA from this
link. Hope this helps...please post back for further assistance. Daniel
