SOURCE: Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
SOURCE: how to remove motor from
Remove back panrl. Remove drive belt, remove 2 10mm motor bolts. Turn machine upside down. Remove bottom cover. Disconnect power lead to motor, disconnect earth lead, gently tap motor out with mallet. Brush mountings then accessible, remove and replace brushes.
SOURCE: bosch maxx plus wfo 2260 will not spin
Sounds like it is not rinsing properly.
If you have not already done so, then check the pump filter.
This is located at the bottom front right of basher behind drop down cover.
Unscrew anti-clockwise to remove and clean.
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
SOURCE: Bosch Maxx 2260 washer won't drain or spin.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Plug
off the wall first. Remove the front
lower panel, screws underneath. Be
prepared for water, drain out from drain hose.
Check filter for clogging, clean out.
Sometimes when the load is unbalanced & the machine cannot
adjust
the load it stops. To avoid this make
sure your wash is mixed with big and small clothes.
If
this does not work remove the rear panel & check belt, should have
half
inch ‘give’. Still not good, remove belt,
unscrew 2 bolts that hold the motor, unplug the motor connector, lever
the
motor back with a screwdriver. Check the
motor brushes (at terminal end of motor), if they are any shorter than 1
cm
replace brushes.
Try
these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl click 'very helpful' for the free help, thnks.
