When I want to start my pc i need to hit the ON button 5-8 times and then after a while it finally starts!!! And then when it starts before loading windows l face the main bios checksum error!!! Then after it shows "Retrieving recovery source from Backup BIOS.... Done!" again restarts and everything is normal. I had this problem 4-5 times this week. Please let me know the possible reasons
Take notes of the BIOS settings of your computer for use after replacing the CMOS battery. To access the computer's BIOS, restart your computer and press the "F 10" function key during the restarting process. The BIOS configuration panel will then open and you can write the specific settings for your computer down to use for BIOS configuration after replacing the battery. Turn off your computer and remove the power cable and if installed, battery. Remove the computer hatch which will vary in method depending on the brand and model of computer you have. On some motherboards cmos batteries are soldered in Locate the CMOS battery on the motherboard. The more popular model of CMOS battery used is annotated with a CR2032 label and is a round shaped button. Firmly remove the CMOS battery from the motherboard. Align the new CMOS battery with the positive side orientated towards you and insert into the mother board. Restore the power cables to your computer and restart the PC. During the restarting process, depress the "F10" function key to enter the BIOS setup screen. Update the date in the BIOS and change the BIOS settings to match those you recorded in step one. After the settings are updated, select the "Save and Quit" menu option and restart your computer to finish the CMOS battery replacement. hope this helps
Testimonial: "i really appreciate your help"
SOURCE: reason for showing "check main
your bios has been damaged the bios chip on your motherboard could be damaged to check it In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
restart your compuetr during the boot up process you will see a certain key to press to enter set up (bios) press and hold that key to enter bios using the arrow keys scroll to load optimised defaults
You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
no 'cos all i can do is power button on goes straight into sleep mode so i hold power button on to shut down and i'm straight back where i started
