I need codes for my beko hd 32'' tv as the controw for the tv dont work
On the sky remote press the following
TV
RED + SELECT (blinks twice)
TV
0125
press the volume button,if it works press SELECT if not press TV then VOLUME again repeat this process of TV then VOLUME until it works then press the SELECT button to save the code to your remote.
Enjoy
Littlle Dish Fitter
BEKO
17WLB450S
SKY Rev 6
0081
Peter
C727WNS
SKY Rev 6
0742
Scott Meek
28421NDS
SKY+ Rev 8
0742
Denis Martindale
ND28426NDS
SKY Rev 4 or earlier
742
mike
NR 14272R
SKY Rev 6
398
Dr Vinod Gangwani
NR 142746 TS
720
david
NR15LB450S
SKY+ Rev 8
0065
Tim Hamblin
NR 17WLB450S
0065
CM
NR17LE300S
742
Peter Lyon
NR20212T
SKY Rev 6
0743
Tammie Bowkett
Try these its all i have for BEKO
Beko
0125
514,398
JonnieC
SOURCE: how do you use a beko 32" hd tv as a pc monitor?
Thanks for the detail-
VGA connections are pretty uncomplicated so the only thing that might need setting is the PC's video settings which may be set for higher than the 768 line standard.
The TV may not be sending information to the computer for Plug and Play use but you could try this anyhow:
- Have the TV turned on. the PC off.
- If not still connected, connect them.
- Turn on your PC.
If the TV set is conforming, it should send a signal packet to the PC with information about itself.
You will see early if it had; a Windows dialog box should tell you 'Found new device (or hardware), installing software'
If that or similar did not appear, then after the PC is booted, Open the Control Panel, then the Display folder, then click on the Settings tab.
You will see a linear control for the resolution that will step from one standard to the other, up or down from the current setting.
Unfortunately, it won't change anything until you click on OK or Apply but it pauses after clicking shows the result then asks if you want to keep that setting.
