The microwave beeps 3 times when any button is pushed. It looks as thought he fuse needs to be replaced. Where is the 20 amp fuse located in the microwave?
SOURCE: Kitchenaid microwave bulb
You can download the owner's manual and installation instructions here.
You can also download the parts manual here. It has handy exploded views. The bulb is shown on page 5 and is ref # 75.
You will need these instructions, because to replace the bulb, you will need to pull the microwave down from the wall mount and remove its cover.
Always unplug a microwave before removing or installing any bulbs.
And it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
If you don't find a replacement locally, check here.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
SOURCE: I am looking for a replacement for the Kitchenaid
HELLO,
I have a brand new still in the box KBMC140HSS if your interested please E-mail me at [email protected]
Thanks
M.O'B.
