1) Adjust the REED switch, clean it, and tight the plugs or connector very well, see the diagram
2) LUBE the deck belt, this could be happen to due the lack of maintenance, you must do it every weeks of use, use 100% silicone LUBE, and do it.
3) LUBE the rollers bearing with DW-40 with small quantity.
3) Tight a little drive belt motor, and replace if necessary, the tension must be 1/4" of flexibilit.
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubleshooting motor.
5) Test the output voltage board, for input voltage motor, if there are NOT voltage, the board is faulty.
see the block diagrams
God bless you
