Question about Kodak A270 72-in-1 Card Reader
A271 72-in-1 card reader, I do not have the installation cd.
    New Friend:
    Problem Solver:
  • 7 Answers
It should be picked up by your os system as an external drive, as too my knowledge this reader does not require a cd to run
Posted on Sep 22, 2012
    New Friend:
I concur with solutions #1 & #2 above, but still had problems that turned out to be caused by a loose connection. It took me several attempts making subtle movements of connections both in the USB port on my Windows 8.1 PC as well as the micro-USB port on the A271 device.
So be patient and keep trying by moving the cable slightly and waiting to see if lights come on and PC finally recognizes the device. Once my PC finally recognized the device it still did not have a solid connection and device kept appearing and disappearing; so I made a very slight movement of the USB port connection and finally fully connected!
Prior to the above I had also called the Sakar support line and they told me it's a plug-n-play device and should just work, and gave me steps to power-cycle PC, move cable to other port, etc. Which I had already done without success.
Posted on Jun 17, 2014
    Novelist:
  • 91 Answers
For Windows XP/Vista/7, built-in drivers support the flash media slots (XD/CF/SD/MS).
The install CD is only required for the SIM card slot. Sakar (which actually manufactured this Kodak-branded card reader) sent me this link for the SIM software:
http://sakar.com/images/resources/download-driver/SIMSetup.zip
I haven't gotten mine to work, though.
Posted on Oct 20, 2012
  • Simon Flummox
    Simon Flummox Jan 25, 2013
    After getting absolutely nowhere with the Sakar driver/software, I finally tracked down a package that works with my Kodak A271 reader. The Sunpak USIM Editor:http://sunpak.com/specsheets/simreaderzi...
  • Todd Burse Oct 11, 2019
    this card reader DOES NOT! support SDXC micro SD cards.
6ya staff
SOURCE:
Installing to computer
Jennie, with your camera came a CD. On that CD is the software you need to install on the computer, before you can connect the camera to the computer. On the CD are also drivers, for every type of computer. If you don't have the CD, sometimes after registering the camera online you can download the software. If nothing works, you always can use an external card reader end put the memory card in that. For a card reader you (most of the time) don't need any software, because most operating systems have drivers for the card readers.
Jan 04, 2014 | GE E1450W Digital Camera
Computer does not recognize card reader
You have need to install card reader driver for windows 7, download driver or if you have driver CD install card reader driver then try it will work.
Jun 16, 2012 | GE Televison & Video
Can i use my jazz dvx40 camera without the installation cd?
You can use the camera without the installation CD. The CD may contain some useful photo editing program and help you download the photos from the camera to your computer using the USB cable.
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 10, 2012 | Jazz Cameras
How do you down load pictures to the computer from a olympus sp800uz
You must install special software that came with the camera to up load pictures to a computer with the cables that came with the camera. The detail is covered in the manual of which a copy can be down loaded from http://static.highspeedbackbone.net/pdf/olympus_SP-800UZ-Manual.pdf
A quick method of using the SD memory card in your camera to shoot pictures on, and then removing the card from the camera, plug it into a card reader attached to your computer. You also can insert the SD card directly into your printer if that printer has "PICT-BRIDGE". That means that the printer has a card reader built in. Many newer Lap Tops have a card reader built in. You may also attach a card reader by USB connection to your computer.
In any event all of the above are covered by the manual.
Jan 23, 2011 | Olympus SP800UZ Digital Camera
I have 2gb memory card when i insert the card in computer system but computer system does not show and device manager show yellow triangel explain how i can shortout this problem
From Device Manager; Right click that Yellow trangle and click un-Install. It will remove present card reader driver from your system. then If you have Card reader Driver CD then install it from CD. Once Driver is installed then insert SD card to check.
Mar 21, 2010 | SanDisk 2GB microSD Memory Card
Not work from win98 i am athlon 850Mhz from package is Re-order No00326: 52X-SD-1GB from card is printing 8GB i use this card on USB2.0 To23-in1 Card Reader
in windows 98 u have install driver of card reader from the cd come with your card reader if u not have the cd then u have download driver from the internet here is the one site u can download from it
Nov 16, 2009 | Kingston 1GB Secure Digital Memory Card
I need to know how to install the software for my usb smart card reader
If you are running XP or Vista, just plug the reader into the USB slot and the system will automatically load a driver. If it doesn't, put the CD that came with the reader in the CD drive and run the exe file and follow instructions. You may have to install the software first or plug in the reader first. Manufacturers vary on the order of install.
Sep 16, 2009 | ActivCard USB Reader (BURR100) SMART Card
Actually using card reader i wanted to access my memory card..
You might have to install the drivers for the card reader.A drivers CD will be there with the card reader. insert it to the cd-rom and install the drivers then only your card reader will show up.
Please Vote
Jul 25, 2009 | Microsoft LifeCam VX-3000 Web Camera
Lost driver cd
my installation cd had just broke,and i could not use my driver because of it,...if you could help me...just email me......thanks and God bless
Oct 22, 2008 | D-Link DFM 562IS (DFM-562IS) Modem
Kodak A270 72-in-1 Card Reader Logo
3,671 people viewed this question
Top Kodak Computers & Internet Experts
John Donghia Jr.
John Donghia Jr.
jonathan Hanson
Level 1 Expert
gaucherre
Are you a Kodak Computer and Internet Expert? Answer questions, earn points and help others
