Mixer was working fine for 2 years until I recently put it on highest setting to beat eggs. Does anyone know why. Help.
There are a few reasons this might happen from ugly to easy lets start with easy and work to ugly.
1. check the outlet you are plugging the mixer into...I know I know but it does happen
2. The cord on the mixer might have a bad connection or one of the flag terminals may have come loose or broke, remember all metal fatigues. If you know how to uses a multi meter an easy check by removing the rear cover and check the power on the contacts from the end of cord that plugs into the wall and then goes into the mixer, you can check by Ohms testing (safer) or by live connection to the outlet in the wall.
3. The brushes on the mixer, one or both may have reached end of life, easy and inexpensive fix. They are under the big plastic screw covers that you see on the side of your mixer. BTW they can only go in one way and if not replaced correctly the mixer will not work even if you have a brand new mixer.
4 The mixer may need a new speed control plate rather more involved because you have to speed tune the mixer after it is replaced but inexpensive and can be performed by anyone from the rear of mixer. BUT!!!! The speed control board may not be bad but only that the mixer needs to be speed tuned.
5. It may be a phase control board gone bad, it is behind the speed control plate, again it can be replaced relatively easily but you also will have to speed tune the mixer and it will be a double digit cost on the part ($25.00-$30.00 unless you go to the internet and search sites, you may find on eBay for 12-15 dollars plus shipping.
6. We are now entering the ugly phase. the items above are all the electric problems that you can fix easily and inexpensively. The next requires a complete tear down of the mixer to replace the Stator and or Armature (the motor). You can do it but it will cost around $60-$70.00 dollars for the motor and then $6.00 for a new gasket which you will need as soon as you open the motor head. Some peeps just re-use the old I would not.BUT!!!!
7. The gears may have stripped while you were using the machine on high and has frozen up so that when you turn it on it won't work. If that is the case then the mixer will have to have the gears and grease and gasket repaired. Gasket=$7.00, Grease=$17-$24.00, it only comes in quarts and you get 30 ounces but only need 6 for a re-grease, Gears, there are 3 and they run between $10.00 for one and up to $30.00 for the pinion tower. No way to tell from the info you sent.
I have been fixing kitchenaid mixers for a while and I am only now replacing my first motor. So I think it is an easy to intermediate fix, DIY could spend 3 hours doing and spend $30.00 bucks on parts. The ugly $150.00 to $175.00 and I would recommend a service center do the motor because they will check all gears repack grease install new gasket and do a speed tune when they fix it.
Kitchen aid mixers are great and sometimes need a little TLC and they will last for years and years. If you could explain further exactly what happened during the speed run up and what you were mixing and what model and serial number (can be found on white sticker under base of mixer in the base cavity). then I may be able to narrow down the repair / fix path. If this helps at all please let us know we like to hear if we are able to help.
SOURCE: My KitchenAid Mixer won't turn on
Check your Brushes or bushings or whatever there called ) those little black things on the side of your mixer above the speed selector and the up/down switch) Check to see if they have started to wear down then i recommend taking it in for service. Good Luck!
I had a similar problem where the mixer would also go to fast speed right away. On the back at the top was a screw that was loose. After tightening this screw I had 4 speeds but no stir speed. I unscrewed that screw and a bolt fell out. This bolt went to threads on the inside of the area covered by that back plate. I put that bolt back on and tightened it and the corresponding one on the other side and wala the mixer works perfectly at all speeds. Hope it helps. Make sure mixer is unplugged before attempting anything like this (wires are exposed when the back plate is removed - some kind of flexible circuit board).
SOURCE: KitchenAid KSM5PSGR Stand Mixer - attachments not turning
Hi Gail. Kitchenaid no longer has a Parts List for your model. This means that they consider it obsolete. Do an Internet search for parts. You may get lucky. Good luck!
If this solution has assisted you, please rate it. ricardok45
SOURCE: k45ss kitchenaid stand mixer, i took out the brushes
jrichards - I hate it when that happens! It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature. The concave contact face should be resting completely on the armature. If you've turned it 90 degrees too much, it wont' seat properly. I hope this helps... Howard, Burke, VA
SOURCE: My KitchenAid Artisan stand mixer won't turn on,
It sounds like something is obstructing it or the lever is bent. You will need to take the head apart to investigate further.
