SOURCE: JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
SOURCE: 1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
SOURCE: john deere 42 inch,17.5 hp-was running good then
have you had a look at carb side of things as it may be having fuel starvation probs.. the fuel in line not getting through jets or float chamber cleanly.. also the tank might have contamination from rust or debris..
SOURCE: Have a Sears lawn tractor,
You are going to need to have the carburetor replaced or rebuilt. If that model has a fuel tank under the seat and a feed hose from that to the carburetor replace that hose as it has gunk from old fuel built up slowing the flow of gas. What is happening is the motor starts and uses the fuel in the Carburetor bowl and then dies. the vacuum pulls enough to refill the bowl after a second or two and then it happens again. I had this same problem with a Craftsman ones and had to go through this, very frustrating.
SOURCE: i have a John Deere
I am an ex-z820a owner because these machines are terrible. Deere issued a PIP for these motors and maybe yours has not beed done yet. The best thing to do is get with a dealer see if the PIP has been completed then sell as fast as you can. I traded my z820a on a z920a and couldnt be happier.
