To adjust the temp, which way to lower and which way to raise the temp? All my knob has is numbers and I don't know if #1 is lowest temp or highest...if I want to lower the temp (my fridge is too warm to freeze things) which way do I turn the knob?
To Adjust the Thermostat
Pull the OVEN TEMP knob off the shaft.
look at the back of the knob and note the current setting before making any
adjustment. The knob is factory
set wit the knob directly under the pointer.
1. Pull of the OVEN TEMP
knob
2. Loosen both screws
on back of the knob
3. Adjust lower screw
so it moves in the desired direction.
You will hear and feel the notches as you turn the knob. Each notch changes the temperature about 10 degrees F.
4. Tighten the screws.
5. Return the OVEN
TEMP knob to the oven.
Re-check oven performance and make the
necessary adjustments accordingly.
thanks...I know it was a dumb question, but hey - i didn't want to turn it the wrong way...
thanks again,
D
on the adjustment is 1 the lowest and four the highest
