How do I enable/disable the hourly chime on a Armitron Pro Sport watch? I see I can get the manual by calling Armitron.
Based on insructions for another watch, I just figured this one out. The steps would be:
Get in Alarm mode (press mode button)
Then you can cycle through the following by pressing the ST/STP button
1. Alarm on
2. Chiime on
3. Alarm and Chime on
4. Alarm and Chime off
You can see this with a magnifying glass and watch the center and right hand circular icons at the top of the display.get highlighted.
If you have a watch that continues to beep hourly and anytime you press a button, regardless of you following your directions you can do the following:
1. Take plate off of the back.
2. Locate audio chime circuit connector spring. (Circled in red.)
3. Use a small screwdriver, pin, or appropriate horology tool to bend spring over, and tuck under plastic movement guard. (You can cut off if you'd like, but it may be impossible to repair.)
4. Reassemble.
The circuit completes itself by making contact with the backplate; if the spring is not touching the backplate the circuit cannot be completed, so it kills the beep! To turn back on simply reposition the spring.
This is the only way that i could get my watch to stop chiming. Thanks for the info!
These are the instructions posted on the Armitron website. I hope they help.
1. From Time Telling Mode, press 'B' twice to enter the
Alarm Mode.
2. Press 'A'. Alarm Hours flash. Press 'C' to advance the
Alarm Hour.
3. Press 'B'. Alarm Minutes flash. Press 'C' to advance the
Alarm Minute.
4. Press 'B'. Alarm Time Zone flashes. Press 'C' to select
either Time Zone 1 or Time Zone 2.
NOTE: The Alarm is available in one Time Zone only.
5. Press 'A' to end set sequence.
6. Press 'B' to return to Time Telling Mode.
ACTIVATING THE ALARM AND HOURLY CHIME
1. While in Alarm Mode, press 'C' to activate the Alarm.
The Alarm symbol appears to indicate the Alarm will
sound at the preset Alarm Time for 20 seconds or until
'A', 'B' or 'C' is pressed.
2. Press 'C' again to activate the Hourly Chime.
"CHIME" appears to indicate the Hourly Chime will sound
every hour on the hour.
3. Press 'C' again to deactivate the Alarm.
4. Press 'C' again to deactivate the Hourly Chime.
5. Press 'B' to return to Time Telling Mode.
how to set hourly chime in my sonata digital watch
can't chage day on armitron all sport
I am trying to silence the hourly chimes on my watch
