Drill is approximately 10 years old
Interstate All Battery Center replaced my two batteries for $45.00 each. They replace the defective batteries and place 'date stickers' on the battery packs (982038-001).
SOURCE: I have a craftsmen 18 volt drill. Will it be hurt if I use a 19.
You should never provide more voltage to a tool or motor than what it is designed for. So, as a result, I would advise strongly against it. You have the chance of frying circuits and capacitors very easily by doing so.
On the flip side, using too low a voltage will also result in motor damage. Stick with an 18v battery for an 18v drill.
If you are happy with this answer, please rate this response on FixYa.
SOURCE: 18 volt cordless drill
For USA go here, http://www.dewaltservicenet.com/
For UK go here, https://service.toolcommerce.com/Products/Default.aspx
I work in uk and that is the same system we use, just a few less functions than I get as a service agent.
SOURCE: can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
SOURCE: Jobmate 18 volt chordless drill charging
About 60 minutes...max 90 minutes. Do NOT leave it on the charger for hours and hours...that just cooks the battery.
And switch regularly between the two batteries...else the one that doesn't get used will die.
