Bad smell coming from the exterior of my fridge and the interior is fine
SOURCE: kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
SOURCE: Bad smell coming from fridge
Is there any chance that small food particles have simply fallen into the fan and now trapped near or behind the fan ?
If this is the case, the food may be lodged in such a way that either heat given off from the fan or the fact the food may not be getting cool/frozen any longer, may have sent the food bad and is now generating the smell you describe.
I don't know of any fridge gas that smells like fish or funk as you put it, most are fairly neutral smelling or odorless to a point and certainly would not smell the way you have described.
SOURCE: BAD SMELL COMING FROM THE
There is a drain collection pan under the left side behind the toe plate. Remove the drain tray and clean it.
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
