Freezer is cold and fan is working and blowing cold air. There is a very light cover of frost on the back wall and floor of the freezer. However, fridge is warm. Even when the freezer fan is running there is no air blowing into the fridge. Does this mean the fridge fan motor needs replacing? Any suggestions would be most appreciated.
SOURCE: maytag fridge model # MFF2557HEB
This has to be the evap. fan motor. I have ran into this alot. If you take the vent off the topcenter of the freezer back panel useing a simple flat head unlock the clips. Once you see the fan blades push it with your finger carefully if it spins slow and little wobblely the motor has failed. If it turns not at all then check for 120V. going into the motor by unhooking it if you get 120V motor bad if you get nothing then the Jazzboard or Highvoltage control board has failed. To install a new fanmotor is easy take your time most parts come out with a flathead screw driver and 1/4inchnutdriver. Evap. fan motor is just clipped in.
SOURCE: Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If you don’t know what these are then unplug the machine and let the ice
melt in the freezer overnight with the door open. Then try it the next day, if
is cooling fine then you need to have a service person replace one of the above
items.
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
SOURCE: My refrigerator is not getting cold
You should try to clean the coils under the fridge . Thats a simple thing to try .If your fridge /freezer cant remove the heat it wont cool ,also please make sure your doors are closing tight. We can start on all the free things you can try first..
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
