Water is running very slowly and only making thin ice cubes very very slowly
SOURCE: Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
SOURCE: 11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
SOURCE: Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice
maker needs water. If the valve doesn't seal good because of sediment or wear
it will continue to drip and when the water reaches the ice maker supply tube
it will freeze. You can take the water
line off the valve and watch to see if it drips.
SOURCE: i have an Amana ARB8057CSR Bottom Freezer
Good day,
As long as your sure the temperature in the freezer is within it's normal range, the best procedure is to follow a step by step trouble shooting method to correct your problem.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
