I've run disk cleanup utility. Seriously, it takes five minutes for it to boot. What things can I check/do?
First, go on ebay and get at least another 256MB ram chip for your pc. You should be able to get one off ebay for around $3 and that is including shipping. If you can afford $5 then get a 512MB chip.
Then, Download
The following iso listed below. It is the latest version of the
Kaspersky rescue disk. You need to burn it to a CD with a program like
Imgburn (Which is also FREE like the iso file). Then you need to boot
from the CD and run the scanner.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Now, Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
If you had any viruses or malware slowing you down before you should be in pretty good shape if you run and install all of these programs.
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 if you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If youre not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules you might have to many programs running at the same time putting to much strain on the CPU central processing unit This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. this should speed up your computer
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
try uninstalling a few unnecessary programs
hope this helps
SOURCE: toshiba spa 40 model No psa45e-0184h-en corrupt hard drive
you can now purchase recovery cd's from the manufactuer
kind regards and please don't forget to rate
SOURCE: images and photos are blurred on internet
Try this:
1. Click the Tools menu, and then click Internet Options.
2. On the Advanced tab, click Reset.
3. In the Reset Internet Explorer Settings dialog box, click Reset.
4. When Internet Explorer 7 finishes restoring the default settings, click Close, and then click OK two times.
5. Close Internet Explorer 7. The changes take effect the next time that you open Internet Explorer 7.
SOURCE: Dual Processors for Toshiba Satellite A205-S5000 533Mhz FSB
you got a cheap laptop. maybe from walmart or some other store that was selling it for about $400. It doesn't have a processor that you can switch out. I'm sure it's horribly slow for Visa, so my advise would be to sell it and get something with a dual core.
SOURCE: computer running super slooooow...Ive tried
You can try this
http://www.ccleaner.com/download
to cleanup
this
http://www.hdtune.com/download.html
to check if your hardisk has problem
and this
http://www.malwarebytes.org/startuplite.php
to remove unnecessary start up applications
Do all that and if the problem still exists let me know to give you more instructions
SOURCE: my laptop is stuck. On the screen, it displays;
OMG!
!O_O!
A) Remove ALL Power. Remove the AC adapter (Charger), and Battery.
Laptop closed, work on a table.
(Not a bed, couch, or directly on a carpet floor. She said what? Oh,....well put a clean, static free towel on the table, to prevent scratching it, and the laptop)
Turn the laptop over. Remove the screw/s that hold the Memory Compartment Panel, on.
Remove all Ram Memory module/s. ('Stick')
Ease the spring clips out at the top. When both spring clips are brought out, the ram memory module will pop up a little.
Remove the ram memory module AT THE SAME ANGLE it is in.
If you bring it straight up, you will damage the gold plated contact pins, on the ram memory module, and also the contact pins in the ram memory slot.
Handle the ram memory module by the BODY.
The Body is everywhere on the ram memory module, except the gold plated contact pin at the bottom.
The Body is coated with a see-through protective plastic.
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Note the Side Notches. This is where the spring clip's 'bumps', go into.
Note the bottom Locating Notch. It is actually off to one side.
The Locating Notch lines up with a Locating lug, in the bottom of the ram memory slot.
Means it can ONLY be installed in one direction.
Use a pencil eraser, and clean the gold plated contact pins.
If using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band at the end of the pencil, contact those gold plated contact pins.
Gently rub up, and down on EACH contact pin. BOTH sides. Doesn't take much to remove the 'corrosion'. Don't run too hard.
They won't be bright, and shiny when you are done, but I assure you that you have cleaned them.
(Doesn't take much 'corrosion' to make a bad contact. I use 'corrosion' in marks, because Gold isn't supposed to corrode)
Use air to remove the eraser dust. If you have a can of compressed air for computers available, use it. If not air pressure from your mouth will be sufficient.
Reinstall all ram memory modules. Replace the Memory Compartment Panel, then turn the laptop over.
Reinstall the Battery, and AC adapter. Then plug the AC adapter into power.
WAIT 1 minute, turn the laptop on.
Post back in a Comment with the results.
Regards,
joecoolvette
