Computers & Internet Logo
tony king Posted on Sep 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1992 ford f700 7.0 efi wont run
Replaced fuelpump filter and regulator replaced distubator, button,plugs,wires,module,and coil still not cranking
Anonymous
Level 3:
Top Expert:
  • Master 4,961 Answers
  • Posted on Sep 08, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
4961
Questions
0
Helped
1185681
Points
16067
You should post this question in the car section so the proper experts will see it.
What's wrong with my 1992 Onan Marquis 7000 7.0 generator that starts, runs two minutes then stops?
I had a car in my shop that would run for two min. and die. wait a min and would start right back up. Turn out to be a cracked rotor , the crack would open when it warmed up enough. thy that.
I have a 2006 ford with the 5.4 . It stop running. I put a new fuel filter an electronic fuel module and a new fuel pump And it still want start . I can't tell if I'm getting any fire to the flue pump . I...
To check basic spark get a spark plug tester from auto store for about $5. Remove fuelpump fuse. Remove spark plug, connect to tester. Have a buddy crank car an watch for spark. Do this for each plug. No spark is likely a bad ign. wire or coil. Be careful not to touch electrical wire/plug while cranking as they put out a lot of electricity.
How to test mass air flow sensor on 1992 jaguar vanden plas
If a spark has no path to discharge, it will often find a weak one or create one. If your wires or plugs are so bad that they cannot pass a spark, the coil will discharge elsewhere. It is a great coil. I have seen brand new plugs completely disable an engine. Completely. I have seen wires completely fail on their maiden voyage. The plugs were Champion BRF52 on a Ford, the wires were Belden for a V6 Mercury. I do not recommend Champion plugs, at all. I do however like Belden quality. You would not suspect them, but... Suspect them. Pull one out lay it on a steel part of the engine, and see if it sparks. If not, replace them. For wire, try to start the engine at night, watch in the dark for arcing wires. Replace them.
1helpful
-turns over but won't start -changed fuel filter
Check your battery as it supplies juice for the coil. Then check your coil or coilpak and the crankshaft sensor. The bad spark may be an underlying reason for how the truck has been running.
Do you know if the fuelpump is working? The Inertia sensor may have tripped while you changed regulators. You may need to reset the button on it to connect the fuelpump.
2answers
Wont start
Check your rotor, distributor cap, coil wire.did you change the module inside the distributor cap.
Grand Canyon Tech
Grand Canyon Tech
