Cleaned coils yesterday.
SOURCE: u-line combo not making ice. Have cleaned
bad water valve, thermostat, freezer not cold enough, make sure the ice maker metal rod is at down position or on back of the ice maker plastic water line is frozen. also depends what year combo you have, there operation is a little different.
SOURCE: the door to my under the counter uline
The hole on the bottom of the door might be cracked. What model is it? you might need a bushing for the door.
SOURCE: uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
SOURCE: our uline ice maker is not producing ice at the
Replace the thermostat in the ice maker control head.
SOURCE: water still runs into ice bin after trays are full
This happens when the motor is running slow or the water switch is sticking. To take care of both things you need to replace the faceplate on the icemaker.
