Bowflex Revolution Home Gym Logo
Posted on Sep 06, 2012
How to replace the yellow ******** a bowflex revolution
The yellow strap inside the engine broke
tip
Bowflex Revolution Assembly Manual Download
Download Bowflex Revolution Assembly Manual
Would you like to review the features of the Bowflex Revolution Home Gym?
Have you lost your Bowflex Revolution Home Gym Assembly Manual?
Would you like a digital, searchable, pdf version of the Bowflex Revolution Home Gym Assembly Guide?
Follow this link (& click FREE) to download a pdf version of the Bowflex Revolution Home Gym Assembly documentation.
I hope that helps.
___________________________________________
Download Bowflex Revolution Users Manual
on Jul 03, 2010 • Exercise & Fitness
tip
Bowflex Revolution User Manual Download
Download Bowflex Revolution User Manual
Have you lost your Bowflex Revolution Home Gym Owners Manual?
Would you like a digital, searchable, pdf version of the Bowflex Revolution Home Gym Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bowflex Revolution Home Gym documentation.
I hope that helps.
How do I fold the bowflex revolution
There is a pop pin on the support at the end of the seat rail that must be pulled out to fold a Revolution up. You might want to download the complete operation manual, it is available directly from the manufacturer at bowflexcatalog.com. The product manual link is at the bottom of the page.
tip
I hope that helps.
tip
I hope that helps.
Broke bowflex
Yes. Contact Bowflex directly and speak to a customer service rep. They will assist you with part # and prices. If you need part schematics ask them to send via e-mail. Put in a file so you will have them in the future.
Wrong seat pad with 5.1 bench
They (Bowflex) should replace the seat with the proper seat. Sometimes a picture can go a long ways. That provided they should ship out the correct seat.
25helpful
4answers
Pulley system "off track" inside main frame of 2005 boflex revolution
I had same problem. I fixed it by taking plastic sides off using a long phillips head screwdriver. Jay, you don't have to take the sides off to fix your problem. The sides come off only to untangle and rewind cables on pulleys. Pull the cables all the way out. Have a helper pull out and keep holding out the tension knob This is shown at the bottom of page nine in the manual. With someone holding the tension knob out turn the large pully located beneith the tension knob CLOCKWISE! I screwed mine up by turning it counter-clockwise. This winds the handle to the top and if you start with all the cable pulled off the pully, the cable should then wind itself nicely back onto the pully. Once the handle is all the way up, with the round ball on the cable jammed up against the pully, then and only then let go of the tension knob and let it fall back into place. If the handle falls down a few inches repeat this proceedure but push lower pully a bit harder and try to turn tension knob, while it is pulled out, in the opposite direction and it will then click into place one notch tighter and should hold the black ball on the cable firmly against the pulley. Let me know if this was helpful.
Adam
Top Bowflex Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
