No sound on the tv but everything else works
Hello
Check whether 'mute' function is On. If it is ON, normally a embelm of speaker with a red cross over it will be displayed on the secreen with most of the TVs. You haven't given any details of your tV, brand name, model number etc:- so, i can oly give you general flault description. If mute is OFF, and still there is no sound output from your TV, check its speaker first. If speake is OK, check the set for it audio output, by connecting it with an external amp, by connecting the audio out rCA socet at the mack of the tv, to the audio 'in' of the amp. If there is audio out from the TV, you can heare audio through amp. If there is no audio from amp also, make sure that the sound fliter circuit inside your tV is faulty. If there is sound through amp, and no sound comes by the loudspeaker of the Tv, make sure that the audiou output section circuit inside your tV has the fault; provided speaker is good. OK.
