Coils are frosted up and I want to manually set my defrost timer to see if that is the issue. Where is the defrost timer located on my 596 series Kenmore refrigerator
If you get the complete model number which is located inside the refrigerator on a tag either on the upper left or right wall or the roof inside and then go to partselect.com you will get an illustrated blow out and you'll be able to see exactly where every part is
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
SOURCE: Kenmore Fridge #596
i found the defrost timer for my Kenmore 596.62239200 / freezer on bottom. it was in the top of the refrigerator compartment behind the light bulb console. had to remove the light bulb cover and then there are two visible screws that hold the defrost timer to the light console. the timer is up on top of the console and is not easily seen. ordered parts on www.repairclinic.com.
SOURCE: refrigerator keeps running
I have the same problem. I called a service rep for G.E. and he said that there are 3 thermodisc
sensors behind the white evaporator cover. He gave me a price to repair that was completly out
of range for the problem. I paid him for his service call and sent him on his way. I then decided to
to order the parts from a factory online parts center at less then half the cost of my estimate not
to mention that when I was ordering the part the Factory emailed me a complete parts breakdown showing the Thermodisc and that my unit only has 1 thermodisc not three installed from the factory.
I ordered 2 one for a backup just in case. I deiced the buildup and installed the disc after 24 hours the refrigerator was working normal for about 4-months. Once again the refrigerator iced up and stopped cooling so I called the factory tech support and they told that it is normal to have some ice on the cover of the evaporator and the thermodisc is at that point supposed to open the cooling circuit to let the unit go into defrost mode and then close again. The Tech said that I had a bad
Thermodisc again so I put the spare one that I ordered in and it also worked for about 3 months
now I have the same problem ????????
Brad
SOURCE: How to check defrost timer on Kenmore side by side
You don't have a defrost timer, you have an adaptive defrost control which determines when to defrost based on how often door is opened etc. If you have a defrost problem check
, defrost heater, defrost thermostat
How to check
everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the heater and thermostat are ok it’ll be the control.
Testimonial: "Thank you"
