I had to clear RTC RAM and now I have no sound. installed drivers from CD and nothing. Tried to instal newer versions from the website and nothing still... device manager shows no sound board and the driver is installed and showing on the control panel.
SOURCE: I had a trouble with the usb driver of my p5kpl am
install chipset driver from ur motherboard cd and then try it again
if u still facing same problem better format ur window again
SOURCE: Asus P5KPL-AM SE no audio
try to check ur cd driver(written there is that cd is working on windows vista). ur mboard is high-end and most of the driver is compatible to windows vista or higher operating system. you can actually download the driver thru the internet and make sure that the said driver is window xp compatible.
tried every suggestion and nothing worked for me. Eventually I did a restore and everything turned to normal...
