The diagram I have asked for should be in the Serivce Manual if someone can get me one!The diagram I have asked for should be in the Serivce Manual if someone can get me one!
Usually a person reads the Service Manual before you start tearing the machine apart. Most manual have a diagram so when you get it apart you can see what maybe missing. A trouble shooting section is a helpful section a Service Manual.Usually a person reads the Service Manual before you start tearing the machine apart. Most manual have a diagram so when you get it apart you can see what maybe missing. A trouble shooting section is a helpful section a Service Manual.
You can't post conmments that contain an email address.
If it will neither drain NOR spin, the problem points to the Lid Switch.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
Thanks for your help
