Top refer unit stopped cooling, still hear the fan running, but the freezer drawer unit on the bottom still works fine.
Most likely you have a bad damper,go here to see it
http://www.repairclinic.com/PartDetail/Damper/67003410/1025326
all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air to the fridge section and it goes through the damper,when it gets cold enough in the fridge section the thermostat on the damper closes the damper door,your damper broke in the closed position,this is as long as the door wasn't left open or anything like that,if it was the air ducts could have froze up but most likely it will be the damper.go here and it will show you where it is up near the light in the back and it's part number 18.hope this helps
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ARB2217CWPARB2217CW1/1268/0161000/M0403273/00003?blt=06&prst=&shdMod=
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
SOURCE: Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
SOURCE: model number ARB2217CW Amana Refrigerator Bottom
I would check the circulating fan. This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and the frig.
SOURCE: Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
SOURCE: i own a amana fridge
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Water Running in refrigerator from Freezer
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
